BreakingBad
Banned
ok so i have had a TON of trouble with my system ever i had a local install bay do the install, as seen in the installer review section of this site..
anyway, i had my amp sent back to us amps, they 'repaired' it and said my capacitors were bad, they 'fixed' it and as soon as i go and hook it all up, it was poundin then all of a sudden.. bass cuts out and i hear a crackling noise.
first thing people said.. check your rca's. so i did. they were frayed (the outside material) so i figured it could be interference or bad rca's. got new ones, same problem occurs.
normally before it was to the point where i could listen to the bass for awhile, and it would cut out later. now its as soon as i turn the HU on. its a 'scratching' or rubbing noise coming from the sub, so i thought it was the voice coil rubbing.
with the HU on, if i have volume at 0 and push slightly on the sub in the downwards motion, it makes the rubbing noise.
if i turn off the HU, and repeat the same thing, there is no rubbing.
the HU might be defective. could it cause this issue? you should be able to change the colors on the buttons into like..4 or 6 different colors, and all that works for me are like red green and blue not the other 3.
anyway, last night as i got out of my car i saw lines through the screen on the HU. literal lines...like a HRline on a webpage. couldn't see it in daylight.
i'm just concerned aout the sub.. is it screwed now b/c of something sending it distortion, or could the crackling noise be from the HU?
