Is it hard to install everything?
In my opinion, its very simple to install hu's, amps, subs , and eq's. Eq's are no harder than anything else they only consist of a power wire, ground wire, acc wire, input jacks and output jacks. Its all very common sense once you learn it. It just seems like a lot when it is new to you.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
is it hard to stop the clock on your VCR from flashing 12:00? no, not really, but, some people just can't handle it. it just depends on if you have the balls to try it and succeed. if you put your mind to it you can do it.
mE PERSONALLY i would try it myself thats how i learned and now i'm a certified pro. , but on the other hand if its your first time your GONNA *UCK SOMTHIN UP so take it to the pro's who know
You won't "F" anything up as long as you don't wire anything wrong!!!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif But i would take it to someone who knew what they were doing first before i messed with it. The cars nowadays are alot easier to mess a lot of wiring or computer stuff up than the cars i learned on. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
main things are...be careful with the power cable (don't touch metal when your touching the end of it (hell don't ever touch the end of it), and always remember...fuse has to be no more than 6 inches away from the battery.
everything is actually real easy...take your time...
i would say if it is your first install ask a friend or someone who has a little experience to help you out...
if you dont have one just take it to a pro its not worth f'ing up your stuff... and it doesnt cost that much to install anyways
Originally posted by Charter16 if you dont have one just take it to a pro its not worth f'ing up your stuff... and it doesnt cost that much to install anyways
whooooaaa! i dont know which planet you are from. but, here on earth it costs an arm and a leg for installation!
That aint no lie! :p An arm, a leg, and half a nut sack!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Originally posted by gator4thehaters That aint no lie! :p An arm, a leg, and half a nut sack!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
uhh uhh... he said "nut sack"... uhh uhh.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
take your time, take it 1 piece at a time
1. head unit
2. amps
3. speakers
4. subs
don't try to cram it in a day, but you don't want a mess in your car drivin
i'd say get a friend who knows about the stuff to tag along
Go ahead and do the install your self man. Just dont do anything without making sure you know how to first. AND remeber you got the best help around the INTERNET! Anything and everythin you need to know about installing a system is on the internet. Most of witch you can ask right here on these forums. Need to know how to put in a HU? Its very easy but go ahead and ask under the headunits forum. Need to know how to install your amp goto the amp forum and so on. Good Luck
Daniel
Caraudio.com
Daniel
SFLA
gibasscarguy
