Is Cadence wire CCA or OFC
Based
I just wired my second battery with Cadence 0g and I bought it because it said it was pure copper or w/e but I read more up on it just now and people basically say it's cca...
It is silver on the inside copper on the outside...
If this **** is really CCA and not OFC then I'm just going to order 100 feet of SHCA 1/0 awg and redo my big three and my second and third battery wiring... **** my life...
**** my life I'm so pissed............. ****..............!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Well that's 50$ down the ******* drain god ******* damnit........ ****
I mean I'm trying to run about 4K watts (subs + front) in my system. two rear batteries a 320a alt and an agm in front... Do I need 2 runs or w/e?
I run about 5k total rms with about 800 of that being class ab and i have 2 runs of pos and 2 runs of neg with a duracell agm under the hood and 2 100ah dekas in the back with a externally regulated mechman alt @15.1 and i drop to 14.2 full tilt ..so yea id run 2 runs of each .or u can run sky high 2/ 0 or 4/0 welding and run just 1 run pos and 1 neg
2 runs of pos and 2 runs of neg should be plenty the cca should be rated for 250a per 20ft so 2 runs would be 500a and if the run is not 20ft its even more amps
Well the biggest run I have is from the front pos to the back first battery pos and it's about 15 - 20 feet. right now it's one run of the cadence wire. Should I just do another run of the cca just like it then do everything else with ofc because I'm out of wire I need to order some more this coming friday so should I order 25 more feet of cadence of should I order 50 feet of sky high ofc
Based
Based
Louisiana
Based
