Is a battery Isolator really needed?
APitBullT
I wanted to know if a battery isolator is really needed?
Well i have 2 batteries, one of them is under the hood and that one is an optima red top, and the second one i was planning to put it in the back and that one is an optima yellow top. The yellow top is not hooked up yet. ive been trying to get help on this problem but no one likes to talk about or help on this subject. Just give me your opinion if a battery isolator is really needed.
everything is in my signature if thats needed at all...
You don't *need* one for it to work. The purpose of the isolator is so that you don't drain your starter battery while your playing your stereo with the car off. All the power comes from your 2nd battery.
ok say if i dont have a isolator and i have both batts and my car is off and my music is playing, is it still going to drain my main battery even with the second bat?
As I understand it when running more than 1 battery without an isolator the 2 or more batterys must be Identical in every way. If using different types and sizes of batterys an isolator is required.
Heres a snippet of info from an FAQ-
2.10 When should I upgrade my battery or add a second battery? [iDB]
The battery is most important when the engine is turned off, because it
supplies all of power to the audio system. The stock battery in your
car may not be up to the task of running a stereo with multiple (or
large) amplifiers if it can't supply enough current to the amplifiers.
Upgrading your current battery to a larger model may help solve the
problem because batteries like the Optima 800 offer a larger number of
cold cranking amps.
Generally, adding a second battery is great if you want to listen to
your stereo with the car turned off (and be able to start the car again
later!). This is accomplished using a dual-battery isolator: a device
which allows the second battery to be charged by the alternator, but
prevents the amplifiers that are connected to the second battery from
drawing any power from the main battery. Installing a second battery
may be done instead of upgrading the main battery.
Sorry to threadjack, but its on topic:
Is everyone using the same batteries in there multi-battery setups?
Do you guys run the wire to the 2nd battery from the 1st battery or from the alternator? Does it matter?(I'm going to guess it doesn't)
Sorry to threadjack, but its on topic: Do you guys run the wire to the 2nd battery from the 1st battery or from the alternator? Does it matter?(I'm going to guess it doesn't)
yeah i also want to know this. How would you wire the batteries?
is there any pictures that give you and example (like the engine bay, the second battery all wired up)?
APitBullT
APitBullT
Scottsdale, AZ
APitBullT
BP1Fanatic
BP1Fanatic
