Hey everyone, i am about to install my new setup so i wanted to see what you guys though..
I will be hooking up 3 amps. (Kenwood Excelon X521, X811D, X811D) (180amps worth of fuses between all of them) however i will only be running them all at about half power.. as otherwise it would blow all my speakers/subs.
So i am going to run wire from my batttery to a distro block then 4awg to each amp..
The distance from the battery to the distro will be around 15ft.
Is 2awg big enough to run from the battery to the distro?
Then also for the grounds can i just run a 4awg ground from each amp to a single ground point? Or do i need to run the grounds into a distro and then ground a Big wire?
Thanks,
Thanks,
