iPhone 5 Thread
Never liked apple, especially after my ipod touch just randomly stopped working one day from the battery shorting out and nearly catching on fire. Luckily my headunit supports an SD card so I just put all my music on that.
My headunit does have a USB port, however my iphone serves as my hub of digital everything:music
movies
pictures
GPS
address/phonebook/bluetooth calling
Pandora
Maybe I'm missing somethin here. On my iPhone I plug the USB cable from my phone to my headunit and all my music, pandora and even phone calls come thru. The new lighting plug will still be USB on the other end....
Yea it will, but that means you will have to buy that adapter. Also, it means that if you share a car with someone that plugs in their iPhone/iTouch in the car sometimes, they will not be able to because you will have a lighting port, not an ipod port. Furthermore, another $70 to buy from Pioneer.
What do you need an adapter for? Use your charging plug. plug the USB into the radio, plug the other end in your phone.
doesn't support Video-out.
Also, apparently the new Iphone 5 does not let you control, surf, or browse playlists and active iPhone controls via the lighting port. WTF is that about?
Whaaaaaaaat. THAT does $uck
At least from what I've read, it won't be compatible with the adapter. I'm assuming that Pioneer, Kenwood, Alpine, etc will pay apple BIG $$$ to license lightning to usb adapters that will allow this function. If this function is removed completely, I'm sticking with my iPhone 4. Plus, I feel like its so dangerous to use the iphone to control while driving, using a headunit (esp touchscreen) is a lot safer.
Thank you. Why would u do something like this? Play it off your iPhone. Or Blue tooth. Just off the Head unit. USB is what u used or was this...
It all works fine, I had to change the Bluetooth connection type on my iPhone from being blank, to car stereo
  • Locked
Apple Iphone 14 pro MAX 1tb / Sony Playstation 5 New I am selling the Apple Iphone 14 Pro Max 1TB , brand new and original . Text : ‪(612)...
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
clickclickw00t
clickclickw00t
United States
clickclickw00t
    May 20, 2024
    May 20, 2024
