interchangeable port
  • 5
you just make two diff ports with same foot print but diff lengths
seal them with foam tape and screw them down
this is a crude sketch but you get the idea
Just make sure to use threaded inserts to mount the port wall other wise after only a few changes the holes for the wool screws are going to get worn out and you wont be able to us them any more
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
713
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
887
862
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
9515ROB
TEAM DTF
9515ROB
Sherman IL
thegreatestpenn
audiobaun
    May 19, 2024
    May 19, 2024
