Instead of a distribution block...
HellyHans
Ok, here's my dilema
1: My amp has 8ga wire comming from it.
I'am running 4ga positive from the battery.
Instead of a DB, can I buy a capacitor and wire the 4ga to it and then have my 8ga positive wire from the amp connected to the cap??
2: if not.. I will need a DB. since its a 8ga wire comming out of the amp
If I get a DB block with 4ga in and 8ga out will I need to get a DB for my ground also,4ga to 8ga? As the ground must always be as big or bigger the the power right?
My 8ga wire will be no longer than 2 feet out of the amp
3: And If I get both a cap and DB... where should the cap be? between the DB and AMP or before the DB? will I be able to run the ground wire from the amp the the - negative terminal on the cap which will be grounded with a 4ga.?
thanks
Eww dont get a cap. it wont do you any good.
Ok, I dont want to start a thread of... IS A CAP WORTH IT OR NOT?
I just want a clear answer to my questions..
If your suggesting not to get a cap.. can you atleat answer my questions about my DB....//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
And what the hell is that guy doing with the dam bell in your sig?? lol
buy a dist. block -- it's cheaper than a cap. The cap won't do much for you if you got it
what kind of amp are you using?
Orion Hcca 225
I will be running 1ohm which should give me 400 RMS on Alpine R DVC 10"
Forgot to mention I listen to rock, so not alot of heavy bass driving.. more of SQ than SPL
2: if not.. I will need a DB. since its a 8ga wire comming out of the ampIf I get a DB block with 4ga in and 8ga out will I need to get a DB for my ground also,4ga to 8ga? As the ground must always be as big or bigger the the power right?
thanks
2 - Get a DB, you can get a DB that is 1/0 in, and 4 awg out, or 4awg in and 8awg out. (the 1/0 and 4 out would be if your planning any upgrades down the road)
Ground MUST always be the same or bigger. So get a NON Fused distro block, with 4awg in, and 8awg. If your amp only takes 8awg a 4awg wire wont be good, it will be prettttty big near your power, if they touch wont be good //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
3 - If you get a cap & DB, cap should be as close to the amp it would be connected to. If you really want a cap, i have a PG 1 farad fs 40$ plus shipping. I don't use it at all. no room for it.
i wouldn't bother with it, BUT its up to you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ok, I dont want to start a thread of... IS A CAP WORTH IT OR NOT?I just want a clear answer to my questions..
lol, sorry i just saw that you wanted to get a cap, so i wanted to stop you as fast as i can so you dont get one. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Like what the guy said above, just buy a distirbition block bro. On ebay, they are good and pretty cheap.
What do you think that guy is doing? He's Cleaning the Bell Of Course. In a LIVE College Football game. LOL
What do you mean by " it will be pretttty big near your power??
If your meaning that I will have 4ga ON the amp.. no it wont be like this..
My amp has 8ga comming out.. and was thinking of getting 2x DB one for the pos and one for the neg. with 4ga in.
Is this ok??
What do you mean by " it will be pretttty big near your power??If your meaning that I will have 4ga ON the amp.. no it wont be like this..
Is this ok??
Yes, just get 2 DBs.. 1 fused 4awg in, 8 out. 1 none fused at the same
you'll be all set man.
HellyHans
HellyHans
Montreal
bjfish11
