jcraft
Hi all,
SO I installed a set of INfinity reference 6030cs in the car. I fed both channels from a 50x4 RF, one to each crossover and then wired the woofer and tweet back to the crossover. Now, I wanted to make sure my gains are properly set with the amp and I have never had component speakers before. I am doing this by ear so I installed a 1Khz test tone from a cd in HU. Right now my gain is about halfway maybe a bit less. This sounded good out of the coaxials I had. Now, I notice when my HU volume ( goes from 0-50 on display) is 0 to about 35 the test tone is only coming out the woofer and not the tweeter, Once I go above about 35 the tweeter comes on and you here the test tone very well up to 50 on HU is this normal?. I am reluctant to turn the gain up very far as I don't want to blow the tweeter or woofer. They are rated to 90wrms. I did smell a funny smell in the car after doing this but it may be because they are so new and only have been used about a half hour or so. I played music through them and they sound fine. With the test tone and doing by ear will you be able to hear distortion or not. And which will distort first the tweet or woofer. Also, would this be the best test tone to use for this. MAybe it would be best to play the tone and keep only one of them connected to the crossover at a time and see where each distort and use the lower setting. Just a thought as I am new to this. Thanks
