Installation in a Sable
  • 2
ballersmp
6
Italy
Ok heres my problem. I have a 96 mercury sable with electronic climate controls. Is it possible to install a aftermarket radio in the factory opening. All the indications i have seen is that it is not possible. If i were to have manual climate controls, no problem. There are many after market kits available. Which leaves me to belive that in order to install an aftermarket stereo i would have to install it somewhere other than the factory opening. Which leave me with another problem. I live in Sicily and custom installers are few and very far inbetween. Im very proficiant in istalling myself and would be able to handle most installs but this car has me baffled. Theft here is also a problem so a stealth install would be the best. I would appreciate any help you could provide. Thanks
if u could take a pic that would really help us out. otherwise someone on here might have a sable, and they could help ya out.
so u have found an aftermarket kit. one of those should work.
i'm glad u think u can handle this cuz some get on here and are like "o GOD i have to unscrew this, o no i can't do that"
Well the thing is i found a mounting kit. Only for a 96 sable with MANUAL climate controls. And of course i have DIGITAL climate controls. THere dosent seem to be a mounting kit for this. Its an oval shaped space with the climate controls and radio in one piece. I would even consider going to manual cliamte controls if that were possible to be able to use the factory opening. other than that i can find no where to locate the radio. The glove box is too small and theres really no where else.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
ballersmp
ballersmp
Italy
ballersmp
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
