Install
im not a fan of optima battries at all.. a powermaster is much better battery in that price range and will actually start you can on an extremely cold morning.. and will take a quick charge.. optima batteries are designed to be discharged slowly over a long period of time and charged the same way.. a good AGM battery like powermaster or DECA intimidator are much better battery's. i know this from experience.
The positive post on a battery is slightly larger than the negative.
nG
so its really the same **** thing right concerning clamps..
i have a positive one that i wanted to post on the negative side
so its really the same **** thing right concerning clamps..i have a positive one that i wanted to post on the negative side
Well, depending on the clamp... it might not be tight enough... even if you tighten the set screw on it all the way... it might not hold onto the battery terminal tight enough.
You can always try though...
nG
limitkid7
sell wite
limitkid7
GA
limitkid7
