Install Problem
  • 1
G-Wiz
19
Michigan
I was trying to install a CD-Player (Pioneer) for my brother.. I have it all installed and everything, just fine.. but the HU doesn't sit right in the fit kit.. The instructons of the kit tells me to install these equalizer brackets, and then attach the mounting brackets to the sides of the radio mount (so it will fit into the opening in the Silverado)... When I try and put the HU Cage into the radio mount, it will not go in all the way. So I took out the equalizer brackets and put it into the dash. Everything fits ok, but the HU hangs and the bottom part of the face sticks out exposing the metal/cage. I stuck some rubber thing between the HU and the radio mount to keep it from sagging, now it likes to kinda float and stick out from the Faceplate cover that came with the kit.. I am using the 1" faceplate which was the largest one that came with the kit.. Should I drill into the radio mount underneath the HU to get it to stay up that way and then drill into the side (But not INTO) the HU so it will stay put? Or what should I do? Any suggestions please..
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not...
15
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
357
G-Wiz
G-Wiz
Michigan
G-Wiz
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
