install order
30mm
hey guys, i'm going to be doing a complete install tomorrow and i was wondering in what order should i install everything in?
i'm going to be putting in a hu, amp(only for the sub), sub, and speakers
all i have for the install is an amp kit and a wiring harness for the hu.
i'm going to get some speaker cable today.
is there anything else i should need for the install?
I would first install the HU, then run all the wiring including installing the amps and running the speaker wires to your doors then the subs last but not least.
Make sure you have fuse boxes and a distro block to get power to your two amps as well as all the wiring needed.
30mm
30mm
bakersfield CA
j-rod
vegang
vegang
