Install In progress Help!
grtn316
I am installing a remote start car alarm in a 95 dodge stealth.
Questions:
#1. The alarm brain has a door trigger input +/-. My diagram only mentions 1 wire for the door trigger. It says "red/green/sil dots" and its polarity is negative. Do I just hook up the Negative door trigger to the alarm and thats it?
#2. What do I wire these to?
light output (install guide says "negative output for parking light. Some vehicles such as jeep, have negative parking lights". In another harness I have the parking wire wired up.)
status output (install guide says "negative status output that comes on one second before ignition on and continues until one second after ignition off")
ignition output
accessory output
starter output
rearm output (install guide says "the sequence for the rearm pulse: 1) pulse when armed (locked), 2) pulse after starter, 3) pulse one second after remote start shutdown.
disarm output (install guide says "1) pulse when disarmed (unlocked), 2) pulse before remote starting"
#3.
I wired the starter kill and the starter wire together then wired it into the ignition harness starter wire. Is this correct? I wired up the 2nd ignition to the black/yellow wire in the harness according to my wire diagram.
Thanks for your help!
Here is the wiring diagram for my car:
12volts black or white + ignition harness
Starter black/yellow + ignition harness
Second Starter
Ignition black/white + ignition harness
Second Ignition blue/black + ignition harness
Third Ignition
Accessory blue + ignition harness
Second Accessory
Keysense
Power Lock brn/blu or brn/wht - high on firewall by DKP
Power Unlock brown or brn/blu - high on firewall by DKP
Lock Motor
Unlock Motor
Parking Lights+ green/white white molex left kick
Parking Lights- green or grn/blk left of column
Hazards
Turn Signal(L)
Turn Signal®
Reverse Light
Door Trigger red/green/ sil dots - left of column
Dome Supervision
Trunk/Hatch Pin red/green - sw. or light in trunk
Notes: Also blue/white at ETACS if car has anti-theft
Hood Pin blue/black - ETACS mod. under dash
Notes: The ETACS module is located left of the steering column close to the drivers
kick. It is flat with its edges facing up, down, front, and back, with its two(2) plugs on the bottom edge.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green - ETACS mod. under dash
Notes: must be relay isolated from the door key cylinder
The ETACS module is located left of the steering column close to the drivers kick. It is flat with its edges facing up, down, front, and back, with its two(2) plugs on the bottom edge.
Disarm No Unlock
Tachometer white AC instrument cluster
Notes: Also found at ECM behind center console. On SOHC models can also use white/black at the ignition coil for tach.
Wait to start
Brake Wire green + at switch
Parking Brake
Horn Trigger green/black - steering column
light output - its only if you have a negative light input on your car instead of positive, but you have a positive one already hooked up if i read right, so leave that wire alone.
status output - sends an output signal to turn something on when the remote start is triggered, requires relay, if you dont know what it is, elave it alone
ignition output - black/white wire on ignition harness
accessory output - blue wire on ignition harness
starter output - black/yellow wire on igntion harness
rearm output and disarm output - i think its for the factory alarm system, dont think you have one, so leave em alone
also what alarm system did you buy? if you have a separate remote start satellite relay, you should use the 12volt inputs from the ignition harness instead of from the battery directly or wherever else you got it from
i say this because it sounds like you dont completely understand the way the remote start works and you didnt mention these two(or 3) wires.
also where did you get the wiring diagram for your car? do you have a program on your computer that you got it from?
I got a compustar 2wass alarm. This is my first install. I have a factory alarm, do I need to wire the arm and disarm to the inputs on the factory alarm? What do the starter/ignition/accessory outputs do? I wired the 2 12 volt power wires to the ignition harness.
I wired the starter and starter kill wire to the starter wire in the ignition harness. This is wired correct right?
yep, starter and starter kill are right
you need to install the arm and disarm outputs to the inputs on the factory alarm for the factory disarm
the starter wire sends power to the starter from the ignition wires to the starter under the hood, this cranks the motor
the ignition wire then sends a constant power to the ignition coil which keeps the car running after its started
the accessory ouputs supply power to the accessory circuit. so basically when things on your car(like your lights or defroster/heater) that only turn on when the car is on, can start. that way the night before you leave your heater and defroster on and then it turns on when you remote start it.
you could also use one of the ouputs to start the defroster.
i also really want to know the name of that program that you got the wiring diagrams from if you used a program, or if anyone else knows a good one?
thanks and good luck
They gave me the diagram when I purchased the alarm (I think they used a program called directwire). I also did a search on this website and found a free website that has diagrams. They were basically the same diagram.
grtn316
grtn316
Midland
grtn316
