Install help
  • 4
Demon73
I changed out the stock HU on my Mazda Mpv. I used the wire harness adapter and all went well. But I have no dash lights now. I have checked all of the fuses that I can find. I have also put old HU back in to see if there was a problem with my wiring still no lights. I removed the instrument cluster to check the lights and they are all good. The strange thing is I have power on both sides of the place where you install the lights. There is no ground? On the harness there is a orange wire marked dash illumination but no orange wire on the HU. How do I get my dash lights back? Any help?
Its at 2000 Mazda MVP. Looked under the hood also they look good. Someone said something about a relay they called it a tsn or tns that is under the hood.
A sealed Fuseable Link,If its akwardly shaped out of the norm, it is blown, and needs to be replaced
Any idea where I might be able to find the fuseable link for the dash illumination on a 2000 Mazda Mpv.
Have you checked to see if the bulb just needs replacing?Dont remember where that link is,thought it was tucked on the upper side of the dash up high on the left unless that was a toyota
Yes I have checked all of the lights that don't work and they all look good. I'll look for that fuse. Will it be out or wrapped up with other wires? Thanks!
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
957
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
963
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
Demon73
Demon73
Sacramento,CA
Demon73
    Apr 27, 2024
audiobaun
    Apr 27, 2024
