Install help
jadon087
The Snowman
I tried this before but never got any replies. I am going to be installing my system soon and i need some help with my wiring install. MY system will consist of:
optima up front
2 stinger spv70's in the rear
1 sundown 2000d
1 sundown 100.4
what i am trying to figure out in between what spots do i fuse I know i fuse after the front batt but then do i fuse again before the rear batts or after?
How many runs of 1/0 should i do for both pos and neg?
also do i need distro blocks to transition batt to amp 4 gauge or can i just run the wire from batt to amp?
fuse @ front batt
fuse before back batt
you can get away w/o fusing both of the rear batts together or do it if you want
fuse to amps
you don't need a distro block unless if you want to use one.
fuse @ front battfuse before back batt
fuse to amps
so with setup i would say im looking at fusing around 6 times if i do two runs from front to back, correct me if i am wrong
Optima two runs pos 2 fuse
plus another for the big 3.
2 fuses before rear batt
then fuse from rar batt to sundown saz-2000
also fuse from batt to sundown 100.4
Just fuse every wire from the front to the back at the front batt, and before the back batt. Then fuse the wires going to your amps. and the wire from your alt + to batt +. so you should have like 7 fuse.
1-First + run to back
2-Second + run to back
3-Fuse before #1 SPV70
4-fuse before #2 SPV70
5-fuse after SPV70 to SAZ-2000
6-fuse after spv70 to 100.4
7- somewhere from alt to batt.
exactly what i was thinking thanks for clearing that up sir
jadon087
The Snowman
jadon087
Columbia,Sc
jadon087
