Install FM Modulator (novice)
royhoo
Hello, everyone... I'm a poor helpless female on this one, I'm afraid. I have a 2003 Hyundai Santa Fe with a factory-installed 6CD Changer stereo. I have Satellite Radio on a second car with a cassette adapter but, alas, no cassette player on the Santa Fe. So, I purchased the Kenwood modulator made for my system.
I understand how to connect the Satellite Radio to the modulator... the trick is, could someone lead me step by step how to install the modulator?? I have a feeling it's straightforward if you know what you're doing... that would not be me. ;-)
Thanks in advance.
Katy
your antenna wire that hooks into your head unit needs to be plugged into the fm modulator. then hook your modulator into the head unit. run your power,remote,ground wires. modulator should tell you what channel on your radio you need to tune into to hear you signal. do you have an auto on modulator or a manual modulator. i have an auto on and i wish i had purchased a manual instead. mine takes longer than i want to turn off if i switch between the radio station for the modulator and another station. anything other problems let me know.
royhoo
royhoo
Washington, DC
lexus rx
