install battle wounds
Sweet Raptor Jesus, I shuddered just reading that. Did he go blind?? //content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
just wanted to /boggle that there is an appropriate smiley face with one eye. ****in internet.
im an AUTO technician and this is not true. u are right in the fact that if u put the clamp around the coil wire that it will read the ACTUAL rpm times the number of cylinders but it will not increase the output of the coil. the only things that affects the output of the coil are number of secondary windings, secondary circuit resistance, dwell (amount of time current is flowing through the primary winding of the ign coil). the number of cylinders has NO affect on how much voltage ur coil puts out.
yea, i thought about it and you are right.. but i still think getting shocked by a coil wire could be more potentially dangerous since the dwell is faster (the spark occurs more times in a second than it would in a spark plug?)
angryeric116
car audio noob
angryeric116
Bristol, WI
noob with an RS
