input?
  • 2
If your head unit has rca outputs you can use the low-input connectors on the amp. But if your head unit only has speaker leads coming out of it, you have to use the hi-input wires unless you get a rca convertor(not sure of the name of the thing!) that you connect to your h u wires and run the lo inputs off of the amp to the rca plugs. Most newer aftermarket radios have rca outputs though so i'd go with that. Hope i helped!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
6
256
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
661
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
The ZVX 8 doesn’t do well sealed. 1.25 cubes ported 35-38 HZ is what it will like. Very inefficient 8 and wasn’t very impressive to me, even in a...
scottee
scottee
new zealand
gator4thehaters
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
