Inexperienced buyer needs help, good system under $300 or $400?
You'll be fine with that amp on stock electrical.
Great to hear. Now just gotta figure out how to replace the HU and wire the entire thing (which I have absolutely no experience in lol).
My recommendation is:
Amp: Soundstream Rubicon RUB1.1000 can be bought for about $150 shipped for a refurb(your on a budget)
Sub: An Obsidian 12 dual 2ohm series to 4ohm at the amp for 600 watts RMS $138 + shipping
Box: build a 1.75cu.ft ported enclosure tuned to 32hz
What exactly does that mean. The sub is 2ohm wired to a 4 ohm amp or something? Sorry for being an idiot, no idea what's going on haha.
Thanks for the parts list as well.
I wouldn't worry about an aftermarket head unit. The stock one will work fine for now until you can come up with some more cash down the road. That being said, if you can increase your budget to $500 I would recommend the following equipment.
Amp
POWERBASS ASA 600.1x AUTO SOUND SERIES MONOBLOCK AMPLIFIER AMP ASA600.1x NEW 823871003358 | eBay
Sub
SA-8 V2 D4 SUNDOWN AUDIO SUB 8" DVC 4 OHM V2 VERSION 2 SERIES SUBWOOFER NEW | eBay
Line output converter
STINGER SGN12 FIXED POWER LINE STEREO OUTPUT CONVERTER 609098797405 | eBay
Wiring kit
Cadence WK41 4 Gauge Complete Car Amplifier Installation Kit Amp Wire Kit | eBay
That comes out to just under $400, and I'm sure a box can be built by someone on here for around $100.
I got some good 12's FS. Could do one in a box for 190$ in person if you can meet me somewhere along my way to Mohegan Sun
http://www.caraudio.com/forums/subwoofer-classifieds/551342-fs-ft-more-shocker-super-extreme-12s-15-oem-d2-coils-carbon-fiber-kevlar-caps.html
Grab yourself one of the Audiopipe Mini APSM-1300 amps (around 100$ all over the place online), have 100$ left for wiring kit and line level converter (IMO you'd do best to keep factory HU until you can afford to replace and amp fronts if you have the factory Bose system)
Amp
Sub
Wiring kit
You think an SA8 would be sufficient for such a large vehicle?
Thanks for the advice about the HU, both of you, good to keep in mind. Sorry I can't buy your subs, hispls, don't even have the car or the money now (going to other things as of now). I would like to though
these are meh.
yes x2
look into the audiopipe txbff line or eve candy line. lanzar max would also fit your budget and do ok. all about the enclosure
---------- Post added at 08:54 AM ---------- Previous post was at 08:54 AM ----------
these are meh.
yes x2
these are meh.
yes x2
My suggestion is to stop thinking about doing it all at one time on that small a budget.
As Keith noted, forget about replacing the stock HU at this point, and follow the above advice on your sub+amp.
Sundown or Obsidian would be a solid choice for a single 12" sub, and Lanzar makes decent amps for someone on your budget, esp if you can find a used OPTI
Whether you buy new or used, understand that purchasing higher quality stuff now is the best way to go, for two reasons:
1) You get what you pay for , and you aren't going to be happy with the way cheap shizz performs, anyway; and,
2) A quality sub and amp will hold their value so that when you decide to sell and re-do (and you will), you can recoup most of your initial investment.
I have to agree with keeping the factory headunit for now. You can pickup a LOC(Line Out Converter) for fairly cheap. But if you have the Bose system you will need to run the LOC after the amplifier. So if the Tahoe already has a sub (can't remember if you said that in the first post) just connect the LOC at that location. This way you can concentrate the $400 budget on a sub, amp, box, and wiring. If it were me, I would slowly piece this together instead of trying to work with such a low budget. I would use the $400 to either buy a sub and enclosure or amp first. And then worry about buying other pieces when more money is available.
Right now I run an Obsidian 15d2 off of an RE Audio DTS1500.1 with RE components running off an RE Audio DTS750.2. I was working with a budget. The amps sat in my room for about 6 months until I bought my sub and had Dave the Box Guy build my enclosure. Then that sat for another 3 months until I had the money to buy my Pioneer DEH-80PRS. So I say take it in steps. You will be more glad that you did.
And just an FYI: This setup did a 143.2 on termlab. Not bad for a daily system running stock electrical.
Yea, I'm definitely doing this in multiple steps, I don't even have my licence until around Christmas anyways, so the budget can probably go up a lot, I might be doing a part time job in the fall as well. I might just save up for an OA15 or something like that, I really want to make this purchase the only one for a couple years or so.
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
The Jam
The Jam
CT
SaginawBum
    May 31, 2024
    May 24, 2024
