na_rsx
Incriminator Audio FTW
Just thought I share, if I had the monies I would definitely buy one, but I dont so //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Either way my Lethal Injection is more than enough for my bass needs....................for the moment //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
http://incriminatoraudio.com/update/index.php?page=2&product=22
Copy from Nick's post:
Warden Series Extreme SPL Subwoofers
Available in 12, 15, 18, and 21
Dual .7 and Dual 1.4 Standard or Other Custom Options Available
Black Cast Basket
3" 8 layer Flat Aluminum Voice Coil
Black Progressive Spiders with Woven Tinsels - Suspension Options Available
Non-pressed Kraft Fiber Reinforced Cone
Double Layer Foam Surround
130 Oz Neo Column Magnets with Black Finish
Interlocking Aluminum Spider Spacer Assemble
CILD - Center Interlocking Dustcap Design for Easy Field Recones
ADC - Air Driven Cooling - Six Column Vents for Max Motor Cooling
Silver Push Terminals
Wrap Around Rubber Gasket
2500 Watt RMS Rated
We will start taking order for it on May 1st, the first units will ship a week later on Friday (8th).
I get asked all the time - Why is the Warden better?
The short of it is - I spend the last 5 years of my life working on this driver and I consider it by todays standards to be the end all be all of SPL drivers. This driver has a true top plate that will allow full transfer of flux from the neo magnets to the gap. Check out the site for the full story on that. This motor is so powerful we've build them with an overhead crane. Believe me or don't believe me - people will tell you I don't talk the talk unless I can walk the walk. The judge of the truth will be the SPL lanes!
Thanks,
Nick
