Incriminator Audio VS MA audio
No kiddin...
Unless your doing some bad *** competition setup....
If you need that much power to get loud in a daily setup, your an idiot.
I need all that power to run 3 W15GTI's to the max it's an exparment i am doing. i got everything set the box is a 14CU feet ported to 32 HZ with the old viper it was vary loud since the viber is down i want to to give the subs max power and make it a vary loud daily setup!
i dont think you have any clue what you're in for. Dam expensive experiment too //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
will everythings done just need a new 5K amp what do you have in mind!
Have you done the big three let alone upgraded any of your stock electrical system?
Is this for a competition? Yes or no...dont just say its an experiement //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yes upgraded the battary the wiring. added in a monster cap + a big 300A fuse. all the wiring is 0 gage and 72mm wire for the nigative also upgraded the alt wire!
oh we do not have competition in KSA ! yes i want it for competition if thats what you want to here and i like loud systems this is not my 1st!
The cap dosen't do anything.
300A fuse dosen't upgrade shit really... Fuses don't put out power, they just keep to much power from going through the wire
What battery do you have now? Your gonna want more than one...
Upgrade the **** Alternator, or hell, put a dual alt setup in it.
GOOD batteries, not caps, and at least 2. The 20.1 will go lower than rated FOR SURE. I don't know about the MA stuff. You might check out the IA BEASTLY 40.1..it's time is coming soon.
i got 2 big 200A battarys + 1 100A battery thats y i thinke i do not need an alit but is i get the amp and things started to dim then yes i will upgrad the alt to a 300A alot! lets go back the what amp i should get guys. thank you
OH GOD!!!! NOOOOOOOOES!
So what ever happend to 6 XXX 15's? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
That for an "experiment" also??? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You need to do ALOT of research before you think about doing 6 XXX's, or an 20.1... Start reading man.
omega_t666
omega_t666
Fredericton, Canada
denim
michigan born
    May 14, 2026
michigan born
    May 14, 2026
