Incriminator Audio reps/nick w/e
See Post #68
see post #28
haha well i did hook everything up correctly im just no understandung why my amp fried all of a sudden........? i had it poundin my 15 earlier, i hook this one 12 up to it and it fries? idk, i am very furious, and the guy with the jesus in his name your a idiot, iv said several times its a great company......maybe this is why no one on the internet likes ca.com?
umm, I believe this is the largest car audio forum on the net. So is your sub blown too or just the amp?
Ok man, there is a gain setting tutorial around here somewhere. You need to read it, now. Also, go on BCAE1.com and read EVERYTHING about gain setting, preout voltage, and etc. Your gains were most likely set completely wrong and underpowering/clipping were most likely the cause of death. Unless there was some major defect with the sub, this is not IA's fault. There is alot more of a chance that its a simple user error. Learn from it, make sure your gains are set right, especially if you'll be underpowering anything.
i think when you cant push the cone in anymore,and smoke rolls out of the magnet/voicecoil area for 3 min it is infact blown?
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
looks like he clipped the amp and damaged both the sub and amp.........
Nice read for the OP........Sensitivity matching JL style.......
Sorry about your bad luck, but it does appear it was a user error in one shape or form.
Maybe you can get the amp fix and run the other driver, I guess its a good thing when the amp went it didn't take both drivers with it.
Thanks,
Nick
Thanks,
Nick
Indeed, im not sure how i could get it fixed no one around here does that. I think it'd be easier to just buy a new one.
I suggest you ask a mod to remove this thread. There is little point in keeping it up, especially the way post #1 is worded.
Yah they can remove it idc.......btw i have 3 blown subs and an amp if neone is interested.......//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
lambo37
lambo37
SD
BobbyDD
