In ya'lls opinion what would be the best amp?
Well it looks like you'll want an amp that can do around 3000rms @ 1 ohm because you'll be probably wanting to run them down to 1.333 ohms...so in that case you would get a bit below 1000 to each sub..should work out well.
So you need something that's stable at 1 ohm. You get either a 1.34 ohm load or a 3 ohm load.
3000 watt Sundown should do you right. You could give each almost 1000 watts. I am not sure how much more than 750 watts L7s can handle.
Dropped_98
Sykotic Image
Dropped_98
Houston, Tx
IDSkoT
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
