In need of a nice 4ch or 2ch for less than $200, what should I get?
TeaQue
I have a set of CDT COM-626 components on the way from Exige but no amp to push them. The car is a GTO and I've been told that it might sound just as good to just get a 2ch for the components and run my rear polk 6.5's off the HU for fill.
You guys think I should pick up a 4ch for the rears and components or just concentrate on getting power to the components?
I was told to look at the Audion SRX4 but I'd really like to stay under $200 because this was supposed to be a budget system and I'm already getting close to $1k by the time I factor in sound deadening and RCA's, fuse block, etc etc. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I already have an eD NINe.2 for the subs, hows their 4ch? I wouldn't mind having matching amps.....
The nine.4 is a good amp, just a bit more costly than it should be. If you can find one used for around $175, it's a nice option. You could also look into the MB Quart DSC4125 or the Audioque 4x90. Both do rated and are right within your budget.
I'd just avoid running rear fill altogether though. If space really is a concern, i'd pick up a 4-channel amp then run the components off channel 1 and 2, and bridge 3 and 4 to a sub.
TeaQue
TeaQue
Kansas City, MO
quest51210
