Turnt Audio
I put an Alpine ktp-445u (power pack) amp in my truck, and I used about 6' of 12awg wire to connect it to the battery. I want to know if the fuse in the Alpine harness that I'm using, which is right below the amp in the dash, is ok to keep using... or should I put an in-line fuse closer to the battery instead, and eliminate the Alpine fuse?
This mini-amp has been working fine, so would changing the location of the fuse just be a waste of time?
Also, is it ok to ground 2 wires (from 2 different wiring harnesses) in the same spot?
