ya man as long as you dont run each amp above 1600 watts right? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif You should be kicked in the nuts for even attempting to compare a Sundown to a freaking Brutus.
Fine dude, that Brutus will take 0.5ohm all day long at full tilt in 100* heat. Go ahead and strap a pair on that 0.5ohm load and drop them down to 0.25 each for some real power.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Whoever you heard that line of crap from is a moron who obviously hasn't used both amps. A Sundown 1500 will walk all over the bxi1606 and the bxi2006.i can get a sundown if need be but i have hurd this hifonic is the equivelant at the moment.
lawl cause ya ll know those amps can produce 2000W:crazy:ya man as long as you dont run each amp above 1600 watts right? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
That amp couldn't produce 1600watts if it was running at 0.125ohm and 18volts w/ liquid cooling.ya man as long as you dont run each amp above 1600 watts right? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
lol heck ya man. because we all know all amps are equal and can run down to .125 ohm daily //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.giflawl cause ya ll know those amps can produce 2000W:crazy:
it was a joke earlier lolThat amp couldn't produce 1600watts if it was running at 0.125ohm and 18volts w/ liquid cooling.
ya they aint much. also if you can get an Incriminator Audio 20.1 go with those! You can run those into the ground and they will keep going.lol, well i guess i will just have to blow it and go buy a sundown thansk alot man im really pissed i didnt spend the exstra money on the sundown
you can never have to much on tap for when you upgradeya but that is crazy overkill man, cheaper to just change over to dual 4 ohm subs
