Stryker
1996 Thunderbird BOOM!
Dude, you have 4 links up there in my post that have illustrations and explanations.
^^^^^^^^^^^^^^^^^^^^^^^ this
Ok so the amp manual explains it the way you told me in the previous post. so if im not mistaken, i will use amp1 for my positives(from both subs) that will go into the +. and for amp 2, the negatives from both subs go into the positive entry correct? Then i connect a 4gauge power wire from each of the negatives on each amp and connect them together? This and a mono connector is all i need to do?This is what the manual calls for, but they only show one sub, i have 2once again, follow the manual exactly. strapping is not really a genaric thing, and the manufacturer is telling you how to do it to work with the way they designed the amp. strapping another way than what the manual says, can just blow the amp(s) or simply not work. #2 will never work, since you are not actually strapping them without hooking up the output jumpers. the cable is just a control cable, making the master amp controll what the slave amp puts out, so there is no unballance. i don'tr have a manual, but #3 may be the way to sync the amps for equal output, or you may need to use rcas to sync. imho, it's kind of wreckless to tell people there is no risk in strapping, and to do anything but what the manual says for how-to wiring. sounds like you have not done it yet, and you do not fully understand the circuitry. if you have a problem with one amp, it can possibly short out the second. it's just a warning.
Yea ive read the entire manual about 3 or 4 times.http://www.kicker.com/sites/default/files/02KX400_600_1200_1AmplifierManual.pdf
OP, If this manual dont help you, then nothing will. this is simple shit.
Subwoofer Wiring Diagrams
http://www.kicker.com/sites/default/files/SoloBaricL72008.pdf
Subwoofer Wiring Diagrams, Two 2 ohm Dual Voice Coil (DVC) Speakers
Wire your subs like Option 2 on this page, you need a 2 ohm final load.Yea ive read the entire manual about 3 or 4 times. I understand what the manual says for wiring one sub to two amps, but would i just bridge both sub positves and both sub negatives to each of the amp positives to wire both subs to both amps and then jump the negstive on the amp to the other negative?
Well i used to have both wired to just one of the amp. And i remember there was only one negative and one positive wire going to the amp, and both subs were being used, so i assume that the sub wiring is already done, no? Ill do all of this tonite. Thanks!Wire your subs like Option 2 on this page, you need a 2 ohm final load. Subwoofer Wiring Diagrams, Two 2 ohm Dual Voice Coil (DVC) Speakers
If you try to wire them like Option 1 you will fry something. After the subs are wired exactly like the Option 2 diagram you will have 2 wires connected to the speakers that aren't connected to anything else. There will be a positive and a negative, the same as if you were connecting a single speaker, like the diagram in the amplifier manual.
Then connect the positive to the positive on amp#1 and the negative to the positive on amp#2.
Then connect jumper from negative on amp#1 to negative on amp#2
Strap the amps with mono cable from out on amp#1 to in on amp#2
Connect the RCAs from the head unit to amp#1
Connect your power, ground, and remote and you should be all set.
