I'm inFInitely Baffled.
nice work
thanks!
now if you could only clean up all that metal around theres.
i bet the pods (that i help construct in new york) are still nifty.
yup, they're pretty nifty. Don't know what I would do w/o them. I'll be too lazy to build my own.
instead of 2 12s you could do 3 10s //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I have thought of that, but my wallet does not like that idea.
My Soundstream 1600.2 is perfect for two 12"s.
I've done some more minor stuff since I resurrected this thread.
swapped out my mix-matched speaker wire w/ hyperflex 16awg
changed out remote wire
re-ran my power wire.
Once I took out all the carpet, I figured I'd do what I can, because it'll be a ***** to take out again.
started like this:
Power re-ran
hyperflex speaker wire
some cheapo deadener on the floor & expanding foam for vents
carpet padding
backseat padding
trunk still needs to be done... but no time for that //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Geez...so this is what my ex-camry would have looked like gutted. I'm diggin the colored zip ties //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Great job man.
hey nice install man! i too have a camry but a coupe. i just finished my infinite baffle set up with one cerwin vega vmax 12. i think i might put another one in since it wangs pretty good. im having some problems tho.
when i turn up the sound to about where i set my gains to i get this weird knocking sound. not sure if its vibration cuz ive tried holding on to the sub while it does that and it goes away a lil. maybe bigger bolts to bolt the baffle in place will solve it?
I tightened the nuts and bolt as tight as I could.
I'm not sure exactly what is making the noise in your setup. You might want to find the origin of the noise before you can fix it.
Turn up your volume to where your gains are?? HUH?
You put your hand on the SUB itself? Or on the baffle? Sounds like the sub is bottoming out...
James Bang
Hand/Ear Coordination
James Bang
James Bang
NorthFramingham
    Jun 30, 2026
