SenateS684 10+ year member
I'm forced for give my two 12" re res 250w...the rms is 175
those are the amp specs. If I give my woofers 250w each, they will still perform decently if I keep the gain down wont they?ESX Quantum 1752 stereo amplifier. Class A/B. 175Wx2 into 4ohms, 250Wx2 into 2ohms. Can be bridged into any load from 1 to 4ohms for 460, 450, and 500 rated watts, respectively, @ 12V. The amplifier does this through use of selectable synchronous bridging, high-voltage, and true mono modes. The synchronous bridging feature allows for symmetrical clipping, which is an improvement over the a-symmetrical clipping found in most bridged car amplifiers. The Q1752 can be strapped with an identical amplifier for 900W into 2 or 4ohms. Crossover is 12 dB/oct. stereo, 24 dB/oct. bridged mono. Fully adjustable from 50 to 4.2k Hz, switchable high/low, with line output. Bass boost variable from 0-18 dB centered @ 43Hz. This amplifier has both unbalanced RCA-type inputs, which handle up to 9V, as well as miniature 6-pin DIN socket balanced inputs, which handle up to 18V.
