Im a N00b.....Need help!
bump!!!! I have a question.....On the hatch door the two small speaker grills (or the plastic things that over them so you cant see them) are screwed down.....I cant tug on it unless I want to brake the plastic square thing........So how am I suppose to get to the speaker? Also the dash screws are to close to the windshield, do I have to take out the windshield to get to them? What if I dont wanna take out the windshield and just leave those ones in, will it still clip the sound even if I get new speakers?
Thank you
OK
#1Measure the speaker you took out with a tape measure to see if its a 6x9, it wont be 6x9 inches exactly but should be close, they look like 6x9s though.
#2The Boston Acoustic is a good choice if you have the money, if not look in the 79.99 range, the ones Crutchfield have in that range are all decent.
#3 The rear hatch speaker grills don't come off by themselves, you need to remove the entire panel.
#4 You don't need to remove the windshield but you do need to get creative, a 1/4 inch ratchet with a phillips bit stuck in a socket can work for tight spaces, also a closed end wrench with a phillips will work, I't will be slow and aggravating though.
Al1ce1nCha1ns
Al1ce1nCha1ns
Dansville, NY
Al1ce1nCha1ns
