izzbo
I have a new Pioneer AVH-P4300DVD that I'm installing in my Hummer H3. I bought a Metra GMOS-01 so I didn't have to splice into the factory wire harness. I first hooked up the GMOS-01 to the Pioneer's radio harness and just wrapped the wires together and taped them w/electrical tape to ensure everything works before I solder and use the shrink wrap stuff. Everything worked great and I left it in like this for 2 days b/c I was waiting for a video bypass relay to come and didn't want to pull everything out twice. Well the last day the radio would randomly get a mute signal from the car (I needed to attach the mute wire b/c I have onstar and that mutes the radio) so I figured it was loose wires so I took it out and drove a day w/no radio.
Today the bypass came. I hooked that up and soldered all the connections and used the heat shrink for every connection. When I put the radio back in the car the radio is on all the time. I know the red wire is the ignition wire that should turn the radio off. I used a multi-meter to check the connection of the wire and I get a reading (the wiring was not hooked up in the car when I did this, I took it out and I am setting the meter to OHM X1K mode and touching the pins that connect to the red wire on each end of the GMOS-01 and I get a reading) and it seems fine.
My question is could I have messed something up heating the wire during soldering? There is a resistor on that wire. Could I have damaged that which is causing this issue? I didn't have anything plugged into the GMOS-01 or during the soldering though so I didn't over heat the GMOS-01 unit. And my other question is how can I diagnose if it's the radio, my wiring, or the GMOS-01? I put in the stock radio to make sure it wasn't the car and the stock radio behaves as it should. Can I use the multi-meter to see if a current is flowing through the red wire when plugged in? If so should it have nothing when the car is off and power when the car is on? Can I somehow test out the ignition wire manually?
Thanks in advance for the help. I'm just baffled on why it was working before and now isn't? I did see the other thread about a similar issue but I didn't want to hijack their thread.
- Jason
- Jason
