If you needed 4k watts????
what amp for 3k watts plus would like 4k at 12 volts $800 tops $600-$700 perfect
  • IA 40.1
    Votes: 8 9.2%
  • atomic 5k
    Votes: 3 3.4%
  • RD D9
    Votes: 11 12.6%
  • AQ 3500
    Votes: 9 10.3%
  • Sundown 3500
    Votes: 22 25.3%
  • XX Cyclops
    Votes: 6 6.9%
  • 2 kicker zx 2500's
    Votes: 5 5.7%
  • AB 400.1 or AB 500.1 depends on price
    Votes: 10 11.5%
  • memphis 4K
    Votes: 5 5.7%
  • Other-post need something to be very efficient and do rated power at 12-13 volts
    Votes: 8 9.2%
  • Total voters
    87
SWFL
I am looking for a serious monster amp to power 2 12's for daily. First for my electrical to make sure what amp is suggest my electrical can handle it.
Electrical
ATM stock 130 alt, will be a 200 amp power master 125 at idle or 250 mechman alt 100 at idle. Figure the powermaster would be best since it does alot at idle. Big 3 done. 1/0 ground and power to the back battery spv70. Front battery is a gold duralast will upgrade to HC1400 if needed.
I am looking to run 2 12's BTL's, RD alpha's, MX, MT, level 4XL, DD, something that can handle 2000-2500rms.
So for an amp. I need something efficient, that does rated power or more at a true 12 volt rating not 14.4 volts. Want something that has been tested and clamped in real world testing. My budget tops is 800 shipped. the lower the better of course. I want a min of 3k watts but 4-5k watts would be better or w/e my electrical can handle
so what would you say
IA 40.1
AB 400.1
Sundown 3500
AQ 3500
2 kicker zx 1500's
Need it to be efficient and do lots of power, what can my electrical handle once i get a HO ALT and battery upfront. Whats the price range of your suggested amp as well
Or buy something more reliable, like my XX Cyclops //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
x2 If I wasn't broke I'd buy that. Looking to get out of the strapped amp thing and that amp would do nicely.
More batteries //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Used atomic 5000.1 or similar could be had and would be a great choice.
Could POSSIBLY pick up two used 2500.1 Kickers if you're lucky
2 2500's will cost close to 1k bucks. if not more. whats the price on atomic and why so many batteries. I only have room for one battery in the back and one upfront and i will prob have a 125 at idle and 200 max powermaster alt, wouldnd that be better than a 100 at idle and 250 max mechman?
Do RD ALpha Max'z on a RD D9.
price???
price???
D9 is in excess of 1k, if I'm not mistaken. They're hard to find used, as well.
And 2500.1's come around for 400-450 shipped each time to time, just gotta have an eye out.
Could also consider an MM4000.1 or, reasonably, two AP30001D's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Like 750 shipped for a pair bnib and they're supposed to do rated power.
yea would rather have one amp to mount and dont have much room anyway for an amp, as well as a PITA to set the gains on the amps for each sub you know.
How would a autotek 4000.1 do??
I want a HO alt that does alot at idle need it when i am not driving fast and needing more voltage. mechman alt is 500 compared to the powermaster for 300. I think powermaster is worth the money savings for 25 more amps at idle
Well at stop lights and such I will be bumping prob not full tilt. Also is that extra 100 amps worth that 200 bucks difference. Being as i dont get the 125 at idle and only 100 at idle.when you are sitting you need alot at idle and same with when you are demoing or doing a test run on the TL
ok I have another ALT thread get this back on what amp for 4k or close to it for the best price and best efficiceny.
SWFL
SWFL
us
ninjawhiteboy12
