If i do 3 12s type Rs how big should the box be and what tuneing?
Type-Rs are rated for 500w each, and they dont really like being overpowered. Id say 1500 would be great for 3 subs, if that amp is actually putting out rated wattage. Being a MA amp i believe they are rated at 16volts or something like that. Which would actually put you in the 1000watt range on a 12-14 volt....
Just my .02
Type-Rs are rated for 500w each, and they dont really like being overpowered. Id say 1500 would be great for 3 subs, if that amp is actually putting out rated wattage. Being a MA amp i believe they are rated at 16volts or something like that. Which would actually put you in the 1000watt range on a 12-14 volt.... Just my .02
my amp is rated at 2000@2 ohms. I had a single type r 12 wired to 2 ohms in my car and beat on it pretty good every day. I never had an overpowering problem with it.
i would say go with 80inches he knows what he is talking about buddy of mine had a box designed by him and it turned out pretty good even though he didn't enough power.
but if this is going in a trunk i and i know a little about trunks i would say do about 1.5 cubes per sub cause i think that is what the subs call for and go with the port area 80 gave you. now if you are in a suv or ext cab then you do the 6 or 7 cubes and go from there but me i don't like doing those huge *** boxes takes up too much space and if you have a trunk you to make life changing changes to get it in.
Just because your amp can put out 2kw doesn't mean that you did. You'd reach thermal/mechanical limits far before you put a real 2kw to a type r.
no, im just saying i was running alot over rated power and nothing happened. Lots of people way overpower them with no problem. you cant really say they dont like to be overpowered.
no. they can take well over 500rms.
babaganoush123
babaganoush123
chicago
blindskater1213
