Ideal 4 channel amp for my upgraded OEM system
nondem
I've replaced the factory door speakers in my 2017 Ford Crew cab pickup with decent aftermarket ones. The sound is improved but I'd like to get the most possible out of these new speakers.
I've found a wiring harness that lets me splice a four-channel amp in to power them using high-level outputs from the factory Sync 3 head unit(non-Sony/non-external amp). Considering the power-handling I have - how much power should I be driving these speakers with? Suggestions on an amp?
Here is what I have:
Front - Kicker 43CSC6934(3 way 6x9)
Maximum RMS Wattage 150
Peak Power Handling (Watts) 450
Rear - Kicker 43CSC674(2 way 6.75")
Maximum RMS Wattage 100
Peak Power Handling (Watts) 300
It’s going to sound like crap using the stock HU.
I get the whole deal w/the OEM stuff being EQed specific to the OEM speakers. Having said that - just replacing the OEM speakers with these Kickers made a big improvement in the sound quality. I can't imagine adding some punch to the sound would make it bad.
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
977
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
10
263
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
932
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
186
nondem
nondem
Tallahassee, Fl.
nondem
slater
    May 2, 2024
slater
    May 2, 2024
