id max question
aquamoe21
A guy is trying to talk me into buying some id max v2 d4. I already have one of the id max v3 d4. Also he says that it is the id max v2 d4 and it is just as good. I do not know much about the id maxs but from what I do know is that they do not come in v2's. The v2's are the idq's. Am I wrong about this. Please help.
To have a v3 (version 3) such as yours, there would obviously at some point in time have to be both a v1 and a v2 (version 1 and version 2) //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
v2 means that it is an older model. There is an IDMax v1, IDmax v2 and IDmax v3, with the v3 presently being the most current production model (there are a few prototype IDmax v4's). Give me a minute and I can dig up the specific differences between the v2's and the v3's.
Ok, here are the differences per Fred Lynch, formerly of Image Dynamics (and now an employee of Arc Audio):
one thing we al lneed to rememebr is there is a lot of v.3/2's out there that are all from recones etc.... as far as production units brand new of the line the differences is...
V.1 - Sand cast basket = less accurate dimensionally,
not as smooth
less defination in the basket shape
one piece cone
yes the surround was slightly smaller
soldered tinsils
1st generation bifloridian coil cooling design
pigment rate lower on the powder coat
1st generation spider
v.2 - same as v.1 except
newer taller surround, also slightly stiffer
crimped tinsils
new gluing techniques
new glue and adhesives applied
new spider
V.3 - Pressure cast basket = extremely accurate in dimension
higher pigment powder coat
machined mounting surfaces
high detail in design
more defination in design
much stronger than sand cast
Introduction of the D2, D3, D4 coil applications
New assembly process
new radiator design
aluminum dustcap
composite pulp cone
new surround
new spider
new tinsel to terminal junction assembly process
new spider landing application
there are a few more things to it but those can be left in the design books and not on the forum
Fred Lynch
Team Image Dnamics
Image Dynamics Services Tech
Taken from this thread: http://forum.elitecaraudio.com/showthread.php?threadid=56760&pagenumber=2
Vas is just one of the T/S parameters.
But, just as an FYI: Most people agree that the v2's and v3's do not sound the same. Some say it's a small difference, some say it's a large difference; but almost everybody says there is an audible difference between the two.
aquamoe21
aquamoe21
williamsport, PA
squeak9798
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
