ID CTX65cs & MTX Blue Thunder Pro 752 ?
dredey
i plan on gettin ctx ids
# RMS Power Handling: 100 Watts
# Peak Power Handling: 200 Watts
# Frequency Response: +/- 3 db 58hz-22khz
# Efficiency @ 2.83 volts: 93dB
# Impedance: 4 Ohms
# Mounting Depth: 2.75
# Poly-mica cone with butyl rubber surround
so i got a MTX Blue Thunder Pro 752
RMS Power measured at 12.5 Volts DC:
2 x 37.5W @ 4 ohms (
2 x 75W @ 2 ohms (
1 x 150W @ 4 ohms bridged (
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
90 watts x 2 into a 4 ohm load
165 watts x 2 into a 2 ohm load
325 watts bridged into a 4 ohm load
So if i hook up both speakers to 2 ohm i will only get 75 watts to each speaker when they can take about 150, so im underpowering them right?
and how do i hook it up to 2X4ohms if i only got 2 R and 2L speaker connections on the amp
also how do i get the 165 watts X2 outta the MTX , that would power the ctx perfectly wouldnt they?
thanks for any answers yall can give me
dredey
dredey
houston tx
dredey
BP1Fanatic
BP1Fanatic
