audioque1200D & Type r 4ohm
dredey
ok so the audioque does this
510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
are these the watts?
the type rs can take
# power handling: 200-500 watts RMS (250 watts per coil)
# peak power: 1,500 watts
does this mean if i bridge my sub to 1ohm it will receive 1200 watts?
and if i hook it up to a 2channel amp each sub will get 870?
will that be good for my sub because it sayas power handling 500 but it can peak at 1500!
can someone please clear this up for me thanks
also does anyone know whats the biggest size cable can fit it in aq1200d thanks
just 1 sub could probably handle that R.
but with your knowledge, you couldnt.
those AQ specs are RMS ratings.
and you need 2 Type Dual 4 subs to run it at 1ohm to give them the full power.
Either that or what grandprix linked, in the end they will be the same, just because you have 2 sets of terminals doesnt mean you have to use them, save yourself some wire and wire the subs together in the box and run only 1 pos and neg to the amp.
dredey
dredey
houston tx
dredey
