IA 20.1, fine for street A?
But I don't think a single 20.1 is enough power to compete nationally in Street A.
on a National level its not even close to enough power to compete.
if you are competing and are doing it because you want to then
all is good. But if you have goals of putting up huge numbers then
that amplifier is not going to be even close to enough.
I am planning on running an IA 20.1 on 2 10" HDC310's @ .25ohm for street A in comps. Do you think this amp will take it? If not, do you think i would have enough power @ 1 ohm? I didnt think i would but no one seems to want this in a trade for a bigger amp(makes sence). How long will the amp last at .25 ohm?
BTW, this is the older version of the amp(the better one;))
i'll buy it from you when i get my taxes back in Feb.
The AB 400.1 Is also an amp i wanted. But i coudlnt get anyone to trade for it. Ill pm some people. There is an AB 500.1 that was just repaired over on caco. But idk that ill be able to support that much power
what battery do you have?
what vehicle?
what is your goal db wise?
You've got people running 7K+ amps in Street A.
But by the sounds of it you're just looking for something to compete on a local level, so I
dont think the other options are workable for you.. I could be wrong however
you gotta make due with what you've got...
good luck with that..
but to be honest I think it'll be very hard to reach that number..not impossible
but very hard.
since changing subs is not an option then you'll have to go with a much bigger amp
in order to possibly reach that number.
Street Stock is still an option as was mentioned earlier but you'd have to change subs.. of course you'd be allowed a larger battery as well.
As for batt wise your options in Street A are
-Hawker/Odyssey 1700 or 1750
-PM 2700
-NSB 75
-Kinetik 2000
Your best bet is the 1750 if you can get your hands on one at a good price...
SPLluminator
SPLluminator
GR, Michigan
SPLluminator
