I was (semi) successful at strapping 2 amps, but the bass cuts at some points?
It will take around 85amps to do 1krms this is passed what your stock alt is already doing. To help combat this issue you need to run batteries.
so lets make a list.
1. Big 3 (in 4 gauge or larger)
2. 1/0 or larger power/ground if not done already
3. High output alt 250 or higher
4. If you are cheap(most are) then buy a few Deka 9a31s from the forum(get at least 2-3, more is always better)
Stop using both amps until you get all of this. All you are doing is damaging your car and your gear.
There is no other resolution for your problem. So fix it or break it, your choice.
marquisbrah
marquisbrah
fresno cali
sandman911
