I want to hair trick with a single 12
If I tear spiders Ill just recone it. A tline would likely take up too much space. I thought about standing the box up temporarily to try sub back at an angle and port to the side at an angle facing forward. I feel like a TI basket would get me where I want, the current 12 spoke is limiting this sub for sure. well the spiders are. it wont bottom out, just hits the spider limits.
05 XXX's use xbl^2. BL drops off significantly above xmax. I think you might be disappointed with your idea of bolting a higher clearance basket to it to try and push the motor further than it was designed to.
It was rebuilt by PSI with nonstandard parts, but I will take that into consideration
Well im not saying youre wrong. the person who rebuilt it bought softparts and built it up himself. not to factory spec, i suspect its limited. if thats not the case ill build a different sub
nateberrier
nateberrier
Douche, Ohio
nateberrier
