snoopdan
Banned
I actually got dumber after reading this thread //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Maybe someone would want to win an SQ award with one 18 or they just wanted a single sub setup. An 18 would be the best choice despite money, box etc. because of the low distortion.....did you not even read my post
does turning your gain down reduce the size of your box,
does turning your gain down reduce the money you paid for your subs?
does turning your gain down help your conscience when you are thinking, "WHY the **** did i buy 3 times the sub i needed?"
yes, when the advantage is enough... when going bigger doesn't give but a negligable amount of decreased distortion, then no.does turning your gain down on a larger sub not decrease the overall amount of distortion since the larger cone is working less to produce the same output... last time i checked low distortion is what you want in "SQ" competitions
so what does that have to do with subs? hahaha... i really believe you have a mental disabilityyes, when the advantage is enough... when going bigger doesn't give but a negligable amount of decreased distortion, then no.lets say christmas lights worked if a blub in the strand is bad.
If you have 20 bad bulbs you would probably buy a new box of bulbs.
but if you only had 1 bad bulb would you spend the money for a difference no one will ever notice?
And yes i did just look around the room to find an example!
It's called a metaphor, you didn't do too well in 2nd grade did you?so what does that have to do with subs? hahaha... i really believe you have a mental disability
Again pay attension... i didn't ever say anything about 15's or 18's having bad SQ, idiot![]()
I bet this guy has horrible SQ
thats not even a similar situation, so its not a metaphor, and for someone who is questioning someones education level i suggest you look to your very next postIt's called a metaphor, you didn't do too well in 2nd grade did you?
... fucking moronAgain pay attension... i didn't ever say anything about 15's or 18's having bad SQ, idiot
No speaker is perfectthats not even a similar situation, so its not a metaphor, and for someone who is questioning someones education level i suggest you look to your very next post
I never said anything about an 18 not having SQ, idiotDuh, he needs a 13w7
Quote some posts that don't make sensehonestly dude just give up. u make no fucking sence in 1/2 your post and you know so much about sq right?
