misfit138
a whole new type of aids
I hope you can do better than that.ill make you kiss the tip of my dick
Oh, and this:
If you learned an ounce of anything you would know that Caps are fvcking worthless and so are your grounding skills.how do you know i just started this summer and i already think i learned alot
then next time dont give him a choice. caps=fail. and if you have the amps grounded to the cap, wheres the cap grounded to exactly?actually i aked the dude if he wanted to use a cap or a distrobution block and he said the cap cause it looks cool ok so it wasnt my fault
i dont think it was the ground making the noises we tryed multipul grounds i think it was the amp it was a soundstream 200 watt 2 channel he was trying to run 2 pionner 120 watt door speakers i think it blew up the amp idk because i put my amp in there and it didnt make any noises at all then he had this pioner 760 watt 2 cahnnel powering his subs so i took that out and i put in a 4 channel 860 watt amp and it has the sub and door speakers on it and its working fine he drove 3 hours with it and it didnt cut outthen next time dont give him a choice. caps=fail. and if you have the amps grounded to the cap, wheres the cap grounded to exactly?
the rcas were running from the headunit to his 2 channel amp with the subs and i added a compacitor to power that amp and the new amp grounded everything out and powerd everything then used a y cable to make the rcas so they go to both amps and hooked up the new speakers for the highs to the new amp and its makes that werid noise i didnt do anything wrong whys it make that noise
WOW! It does not say that it does that. You misunderstood. You cannot hook mids and subs up to the same channels of the same amp and expect it to work properly. Before you say that is DOES say that, quote the exact line you are reading. Do not attempt to interpret. Quote the EXACT line.if i put 2 subwoofers on it and 2 door speakers will it transfer the bass to the subs thats what it says it does with its gay built in crosover but it doesnt ****ing work
