I really need help finding wires to use.
tmartz
I plan on installing my system myself and need to know all the wires i will need and what guages. I need all the wires that are used if i brought it somewhere to get installed. I am also installing a touchscreen headunit, i dont know if that makes a difference. Please help!
I have a 12 inch Alpine Type R sub @ 4ohms
Power Range: 1800 Watts
RMS Power Handling: 600 Watts
Peak Power Handling: 1800 Watts
My amp is the Alpine MRX-M100
Max Power: 1900W
Per channel into 4 Ohms: 600W x 1 (@14.4V Ƈ% THD+N, 20Hz - 200Hz)
Im a newb when it comes to this stuff, what is vc config and where can i find that. Specs to my sub below. Also how much of this wire do I need, What are some good brands to buy?
Features and Specification
SPECIFICATIONS
Power Handling
CEA-2031 Power Rating: 600 Watts
Dimensions
Mounting Depth: 162mm (6-3/8'')
Mounting Diameter: 275mm (10-13/16'')
Displacement: 0.100ft^3
Added Volume: 0.090ft^3
General
Frequency Response: 23-400Hz
FEATURES
Diaphram
Material: KevlarA? Reinforced Pulp Fiber
Design: 2-Piece Structural Parabolic w/ H.A.M.R Surround (Patent Pending)
Surround
Material: Injected Molded SantopreneA?
Design: High Amplitude Multi-Roll
Spider
Material: NomexA?
Design: Progressive
Voice Coil
Material: 180A? High Temp Wire on Spiral Cut Aluminum Former
Design: 65mm 4-Layer Dual Voice Coil
Are there install kits that will have all the wires i need in one. Will i save money if i just pay for everything if i have it installed at bestbuy?
Yes but are those good quality wires, what is better OFC, Or CCA wire. I heard it is better to spend a little more money and get good quality wire?
OFC has a higher current transfer because it has the least resistance. CCA = copper clad aluminum so it it aluminum with a copper outside. Aluminum has a greater resistance than copper. If I were going the CCA route, I would get a larger size wire than what is recommended for the amp. Your amp calls for 4 awg wire. I'm not honestly sure of the exact differences between current transfer between the two. I was in this same boat long ago and the cheaper price was appealing with the CCA but I went OFC for peace of mind. Skimping on wiring will only lead to bad end results. But many will say CCA is fine as long as you're not running a crazy amount of watts.
tmartz
tmartz
Saco, Me
accuab
