I need to know
Vega
I'm about to get a single 15'' L7 ported to 33hz for now and I was thinking if it's not loud enough I might want a second one later on but I can only fit 2 if they are sealed so would the 2 sealed really make that much of a difference over the one ported and would it be worth the extra money for another box and possibly battery? Or should I just stick with the one and epicenter it? This will be a dialy setup.
BTW the single ported would get more than it's rms wattage but the 2 sealed would get less than their rms wattage.
^ yep, single 15 ported has the potential to get louder. make sure you build the box good and get someone to double check the box design.
if a ported 15" L7 isnt loud enough for you, then you gotta get your hearing checked. those subs are nasty monsters.
good luck with the setup
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif prepare for the pressure
I can't wait.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Vega
Vega
Chicago
Vega
