I need some amp help
  • 3
Ok so they are 250 RMS. SVC or DVC?
So you are going to want to probably send them around...~200-250RMS.
Some amps that come to mind would be... :
Kicker 02KX400.1 ~$350
Phoenix Gold QX500.1d ~$380
Rockford Fosgate Power 500bd ~$300
I would also look at the comparable Tsunami, Crossfire, Arc, Autotek, Zapco, MTX, US Amps, US Acoustics, DEI, PPI, and HiFonics respectivley.
- Steve
will this sound nice on my factory head unit. i have a 94 grand prix special edition. I know it wont sound as good as it would on an aftermarket head unit but is it doable??
that's reassuring. i was worried it would sound crappy and i dont want to get a different head unit because it would be costly and i like the volume controls on my steering wheel.
Thanks for the advice!
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
6
230
11
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
badboy357
badboy357
Missouri
avistar23
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
