I need opinions autotek 3000.1 vs. atomic 3000.1
Redgp
Ok so i was trying to do a build using 2 9512G's but it turns out ill only have enough space for 1 with the right volume in the box. I have an autotek MM4000.1 that was going to power them both. Since im only going to use one i dont need all that power. I wanted some input on what amp i could go with instead of the 4000.1. Should i go with the atomic 3000.1 or autotek 3000.1? which one is less of a power hog? Thanks guys i appreciate all the input i can get
theyre going in a hatchback mustang with a 250 amp and at least one 2000 kinetik. Thats why i want to know which one will **** up less power to see if ill need a second battery because with the mm4000 i was going to run another 2400 on top of the 2000.
Redgp
Redgp
Tucson, AZ
Redgp
