I need new tweeters......
Mixman
Premium Member
Premium Member
I am looking for some .75" 4 ohm or under tweeters to fit in my car.The reason they have to be around .75" is to fit in the a-pillars of my G37. I have a set of JL C5 650 tweeters now. They sound good but I want a little more top end. I really like the Focal sound but the the impedance on their tweeters is generally 6ohms or more. I am looking to stay under $150 for the pair.
To integrate better with the Bose system in my car. I don't want to replace the whole system, I have added a sub and 500/1, so I replaced the tweeter combined with the crossover from the JL C5 650 set. It did sound better. I just a little more high end than the C5 650 tweeter has. The Bose tweeter and midrange are 4 ohms each, so I want to stay as close to that as possible.
you want something that small to sound better then what you have??
most good sounding tweeters are 25-30mm.
I think cdt has a 19mm tweeter.
I wouldnt waste my money cdt tweeters
http://www.woofersetc.com/p2310/TW19S--CDT-Audio-19mm-Silk-Dome-Tweeters.htm
I think JL's tweeters are made by LPG which is a good company.
If you are looking for more top end you will need to go to a larger tweeter 25-30 at least.
you should measure to see if you can fit a 25mm or bigger tweeter in place of the 19mm.
I can fit a tweeter with a total diameter of 1 3/4", so that my include some 1" tweeters. I know that pretty much all .75" tweeters will fit, but the 1" tweeters, I am not sure about.
I had checked out Madisound and looked into these already. The problem with these are their impedence of 8 Ohms. That's double what I need to match the level of my current tweets of 4 Ohms.
Mixman
Premium Member
Premium Member
Mixman
Central NJ
okiedokie
