I need help
Changed head unit, amp, it does it on every source..
There is only 1 thing left.. WIRING.
Either your speaker wires are loose, grounding or your power\ground is loose or bad connection.
And this all assumes all past troubleshooting methods were done properly.
I once heard of an installer having troubles like this. He re did the entire system from the ground up and still had issues. Swapped everything out multiple times and still no solution. He sold the car.
I'm seriously about to just sell it. It's so ******* annoying
What I would do now is disconnect the speaker wires from the amp get your dmm and see what ohms the speakers are resting at. I would also to a reference check to ground as well. I havent seen it in a while but back in the day I remember there were some speakers that would actually ground out through the basket of the speaker itself. And it was just enough to cause sort of similar problems.
Tantricz
Spider Monkeys Baby Momma
Tantricz
GFYS AVE
CrossoverOre
