I need help wiring a MLA module??
HI-C
Hello l have a 2009 Cadillac cts that I'm trying to install a module that splice into the ECM fuse wiring. I called the guy and he had sent me a diagram that said the ECM wire was red / white and was the only HOT wires behind the fuse box in the rear. I checked out all the wires with a dmm and all the wires are red / white and Hot! I need help to get all the juice from my Dc Alt thanks for your help:)
This what i found on that vehicle ....
Have fun doing this car. I got information directly from DEI about this vehicle. Out of all the cars that installers call their tech support about, the CTS is the most problematic. They are not difficult in themselves, but many BCM issues. I just did one a couple weeks ago and the car was just freaking out with all sorts of code trips and stuff. Just be prepared to run into some problems! Good luck...
___________________________________
Big Al
Did you install a module and alt in the CTS you worked on? If so what codes was showing, and was they serious? Did you guys get the install up and going?
HI-C
HI-C
Las Vegas
HI-C
